Message 1 of 17
Wifi failure
We've started to experiment ce some annoying wifi drop outs - we have an EE backup kit installed so it does recover after about 20 mins so we aren't totally without wifi luckily. Openreach say there its nothing wrong with our full fibre  and we've been sent a new Hub2 ( what  a faff setting everything upon again!)  today after just 4 dates we had a drop out again.   no general outages reported locally that we can see - an y ideas?
16 REPLIES 16
Message 2 of 17
Re: Wifi failure
when you received new SH2 you should have just changed the new hub SSID and wifi to that of old hub and devices would have connected automatically but good to know for future reference
are the hub lights remaining blue so you are not dropping internet connection just the wifi from hub to device?  Have you tried changing the wifi channels from smart to a fixed channel and using a wifi analyser to see channels in use near you and selecting a free channel
Message 3 of 17
Re: Wifi failure
What imjolly says is very good advise.
Something else to consider, though.  Is the hub low down?  Wireless goes through things but only up to a point.  If something moves into the way that can turn a strong signal into a weak one.  Better to have it positioned high up.
Message 4 of 17
Re: Wifi failure
I rather suspect by Wifi, the OP means Broadband in view of the mention of the Hybrid device kicking in.
@DillyDally  Do the ONT lights change colour?
Message 5 of 17
Re: Wifi failure
@licquorice   Yes, good point.  I should know better.  That misnomer is becoming rife on the Sky forum lately.
Message 6 of 17
Re: Wifi failure
Hub is on the top shelf of a bookcase with plenty of space
Message 7 of 17
Re: Wifi failure
Internet connectivity to your devices consists of 3 links in a chain. The fibre to the ONT, the Ethernet cable from the ONT to the Hub and Wifi from the Hub to your device.
The first step is to determine which link is failing.
You mention that the Hybrid Connect device kicks in which narrows the problem down to the first 2 links. You now need to narrow it down further by observing the colour of the lights on both the hub and ONT when the problem occurs.
Message 8 of 17
Re: Wifi failure
Hub goes red and then when it links to EE back up it goes purple to show itx using thd back up / then returns to blue
Message 9 of 17
Re: Wifi failure
Goes red then purple the. Back to blue
Message 10 of 17
Re: Wifi failure
And the ONT?
Have you tried a different cable from the ONT to the Hub?
