Message 1 of 2
broadband interruption
I came home and found my broad band light flashing orange. checked the connections they are ok.
So went hard reboot. Now the light showing blue and broadband back.
Why does this happen out of the blue and is hard reboot/power on/off the correct way to deal with this.
1 REPLY 1
Message 2 of 2
Re: broadband interruption
did you check if there had been a power cut or maybe a firmware update?
if just a simple drop in connection then hub would normally restart and resume connection
