Message 1 of 5
broadband keeps dropping
My broadband keeps dropping and when I check says no promlem
4 REPLIES 4
Message 2 of 5
Re: broadband keeps dropping
Have you tried phoning CS 03301234150
Message 3 of 5
Is it your broadband or just the wifi signal that is dropping?
Message 4 of 5
Yes thank you and they said fault on my line sending engineer
Message 5 of 5
Thanks for the update @Mavis1. I hope they can get you up and running soon.
Michael
