Message 1 of 3
bt wholesale speed test advance does not show your IP anymore
Not sure if this it the correct forum for Fibre to Cable BUT ,,,,,, once upon a time, when you used the BT Wholesale speed test,  you could then select advance and input your phone number and it would tell you your Line Profile .
It does not show that any more, Is it browser dependent or has it been removed?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: bt wholesale speed test advance does not show your IP anymore
Works for me in Brave or Edge browsers but Firefox doesn't even display the basic test, just a BT background. Although the advanced tab complains after it's run, presumably because I don't use a BT Hub.
Message 3 of 3
Hi, I can see the speed but not the IP profile of what the line has  limited me to for my location, etc.  It used to show both,,  some thing like  Download 39Mpbs ... IP 42   ... Upload 6.2....  IP 10.0, so you have an understanding of the limits,
