Anonymous
Not applicable
Message 11 of 14
Re: fibre to home
so you wont get to   know if a jobs is overground or otherwise when you make an order ?
Message 12 of 14
Re: fibre to home
@Anonymous
if @ianshawley  uses the link posted by @WSH  in message 4 then the notes will give indication how openreach expect to install the fibre cable as explained in message 4
Message 13 of 14
Re: fibre to home
In 90%+ of cases the way the existing copper service is delivered is how FTTP is delivered, so live in an area with existing overhead service from a pole , that’s how FTTP will be delivered, live in an area that’s ducted (as stated housing build 1990’s onwards ) the FTTP will be ducted , the exceptions can be housing areas that are underground (so no poles) but no duct either  , the copper ‘phone’ cables were buried directly in the ground when the houses were constructed…..these areas are very expensive to retrospectively supply with duct , and poles where there weren’t any previously are generally unwelcome by the residents …hence these areas generally are low priority….some will get ducts (if there is money in the budget to do it ) many will simply be left alone for the time being, a very small number may get poles if the residents don’t object, and a somewhat politically incorrect point of view , if the area is mainly  transient type residents , council tenants etc where no one is likely to complain they may put poles up as it’s unlikely to negatively impact the area like it would in a leafy suburb.
As far as not knowing when you order , you can check online but easier than that , look outside, if you can see a pole and yiur copper connection comes from it , then that’s also how FTTP will be delivered…it’s pretty obvious if an area is overhead service or underground, it’s not as easy to know if underground is DIG , or ducted , that’s why knowing the approximate date the housing was built is a massive clue …..1960s to very early 1990’s will be DIG .
Message 14 of 14
Re: fibre to home
@Anonymouswrote:
so bt are all overground to from the pole is does this depend  on what they find
Bt have nothing to do with supply of the service, that  is in the hands of Openreach. Normally it is the same as the copper service supplied, if from pole or via duct. DIG may be provided via either but cost may come into it.
