Anonymous
Not applicable
Message 2 of 9
full fibre prep? after it was pulled from rollout plan
got a l notice posted the other day strengthening fibre network on behalf of Bt openreach could this full fibre prep?
currently digging around our area
8 REPLIES 8
Anonymous
Not applicable
Message 1 of 9
Re: no longer building for full fibre FTTP?
got a latter thE other day M Group are strengthening fibre network on behalf of Bt openreach could this full fibre prep?
Anonymous
Not applicable
Message 3 of 9
now showing
avaiblele to order soon
Message 4 of 9
Don't get your hopes up.  There are usually months between them putting the cables in and it being ready to order.
Anonymous
Not applicable
Message 5 of 9
yeah but at least i know  has not  been lost all together @WSH
Message 6 of 9
As an idea, I seem to recall it was July when they put the cables in around here.  November when I was informed it was ready.  (And I'm told that's quite quick).  Two weeks later when it appeared on offer in MyBT.
Anonymous
Not applicable
Message 7 of 9
thanks for this i will at least i have some idea now im guessing i shouldint hold out for FTTP in 2026 then ? @WSH ?
Message 8 of 9
If you go on here and register an interest, OR will email you when it is ready to order.  (As I said, it takes the ISPs a while to catch up as the don't update their databases that often.  Sky took 6 weeks).
https://www.openreach.com/help-and-support/express-interest-in-full-fibre
Anonymous
Not applicable
Message 9 of 9
already done thanks
