Message 1 of 6
internet stuck at 10mb
Hi my broadband already 1 week stuck on 10mb should be 70mb not know what the problem
5 REPLIES 5
Message 2 of 6
Re: internet stuck at 10mb
Have you been having problems with your connection dropping?  Often?
If you still have phone use and not digital voice try dialling 17070 option 2 should be silent no noise whatsoever
Can you post connection stats from your router?
Message 3 of 6
Connection status,Connected
Connection type,Fibre Broadband (VDSL)
Firmware version,v0.43.01.15019-BT (Thu Feb 29 23:17:28 2024)
Serial number,+091298+1850008323
Downstream sync speed,11.4 Mbps
Upstream sync speed,19.0 Mbps
Network uptime,1 days 6 Hours 8 Mins 33 Secs
System uptime,1 days 6 Hours 10 Mins 11 Secs
Public Wi-fi status,Active
Message 4 of 6
You need to report the fault to customer services0330 1234 150
Message 5 of 6
@atomss  did you try quiet line test?
Message 6 of 6
Tested and they found fault engineer is coming in 2 days
