Message 1 of 1
ongoing broadband issues - over 2 years and still not fixed!
Hello Folks
I was hoping someone might be able to help with issues that have been ongoing for over 2 years.  We are on FTTC, with the cabinet is located 0.5 miles away, our broadband speed and availability is very unstable, it can be anywhere between around 6-11Mbps download/0.0-0.4 upload, multiple engineers have been out and replaced the router, socket, cables etc but still the problems exist so I was hoping that if I posted some stats on here someone might be able to interpret them and offer some help.
Here's the line stats info and below it the router information, thanks in advance for any replies.
Exchange MARYPORT is served by Cabinet 7
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
 HighLowHigh
 Low
VDSL Range A (Clean)
17.6
13.1
1.6
0.8
11.4
Available
Available
VDSL Range B (Impacted)
17.4
11.6
1.6
0.5
9
Available
Available
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
FTTP on Demand
330
50
Available
ADSL Products
Downstream Line Rate (Mbps)
Downstream Range(Mbps)
ADSL Availability Date
Left in Jumper
WBC ADSL 2+
Up to 2
1 to 3
Available
ADSL Max
Up to 1.5
0.5 to 2.5
Available
WBC Fixed Rate
1
Available
Fixed Rate
1
Available
SOADSL Products
WBC SOADSL Availability Date
Left in Jumper
WBC SOADSL 2+
Up to 2
1 to 3
SOADSL Max
Up to 1.5
SOADSL Fixed Rate
Up to 1
0.5 to 2.5
Observed Speeds
VDSL
Max Observed Downstream Speed
11.6
Max Observed Upstream Speed
0.41
Observed Date
2022-07-20
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise Environment
Status
Bridge Tap
U
VRI
NTE FacePlate
Last Test Date
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
N
SOADSL Restriction
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
Here's the router info:
Product code:Hub
Firmware version:v0.33.00.12274-BT
Firmware updated:Mon Jul 18 10:45:58 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,12 Hours12 Mins32 Secs
Data rate:443 Kbps / 12.968 Mbps
Maximum data rate:482 Kbps / 15.027 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:7.4 / 5.9
Line attenuation:14.9 / 28.0
Signal attenuation:13.0 / 31.8
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:471.9 MB Uploaded  / 2.3 GB Downloaded
Public Wi-fi status:Activated
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
