Message 1 of 2
what equipment will be put inside my home for fibre
The reason is am asking this question is because workmen who are putting the fibre to the poles near me say only a cable will be put in my home to the master socket.
I have just read in a magazine that somebody thought he would just get a cable in his home but the engineers drilled the wall in a place where he did not want it and then fitted a box on the wall , put the router where he did not want it and then fitted something called a relay disc to his pc. He also reported he lost connection late at night.
If i need all this equipment in my home i wont be able to have fibre. I live in a bungalow that has a  dormer conversion and the master socket is under what is now the bedroom floor between upstairs and downstairs. The socket is under where the bed is and built in wardrobes and cabinets wont allow for any boxes to be mounted anywhere.
1 REPLY 1
Message 2 of 2
Re: what equipment will be put inside my home for fibre
