Message 1 of 7
BT Performace test WEB Page
Have this now been turned off and nothing happens?  Guess I might have missed a post somewhere
BTW Performance Tester
6 REPLIES 6
Message 2 of 7
Re: BT Performace test WEB Page
It appears to be intended for business users
Message 3 of 7
@jeb0007
It was de-commissioned on the 10th January 2025.
Message 4 of 7
Yes, BT have removed it and it is no longer functional.
At some point BT might get around to removing the webpage but then again being BT they probably won't.
Use Ookla Speed test https://www.speedtest.net/ or any one of the many you will find with an Internet search.
Message 5 of 7
Ah OK, guess I missed  that one..  Do we assume that EE have something similar?
Message 6 of 7
No, as the test was run by BT Wholesale for all providers that use their core network.
If you are not happy with your speed, then you can use the broadband trouble-shooter, which runs a test for you.
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/bt-broadband-connection-problems
Message 7 of 7
OIK, thanks for the info,,,
