Message 1 of 3
Activated sim without deactivating previously lost sim
Hi,
I recently lost my phone and ordered a replacement sim. It has arrived, I have activated it but its says that phone has no activated sim. Did I need to tell BT to deactivate my previously lost sim? Both sims are under the same number.
Many thanks
2 REPLIES 2
Message 2 of 3
Re: Activated sim without deactivating previously lost sim
Replacement sims are sent out activated, previously they weren't.
Give the mobile help team a call on 0800 800 150 or 150 from a BT landline or BT Mobile, you might need a 3rd sim card and then ask for someone to manage the case and activate on your behalf once you confirm receipt of the 3rd.
Message 3 of 3
If you didn't report the SIM as lost then it won't have been deactivated and you will be responsible for any charges incurred
