Message 1 of 4
BT mobile voicemail
Hi,
I have a iPhone 12 and I can not get BT voicemail to work.
I have got it turned on in the settings on my iPhone.
Any help would be appreciated
3 REPLIES 3
Message 2 of 4
Re: BT mobile voicemail
Dial 1571
Message 3 of 4
I have tried that.
Says voicemail is switched on. But it still doesn't work.
Message 4 of 4
Check this guide :
https://www.bt.com/content/dam/bt/help/user-guides/101571_BT_Voicemail_UserGuide_v4.pdf
As maybe you have not set a PIN etc - but this guide should help you reset things.....
