Message 1 of 3
Calls to 0330 numbers
Are calls to 0330 numbers free from a BT Mobile, or is there a charge?
Thank you.
2 REPLIES 2
Message 2 of 3
Re: Calls to 0330 numbers
Hi @SuperSabey
Calls to 03 numbers are the same as 01 and 02. So if 01, 02 numbers are free, then 03 are also free.
BT_PhoneTariff_Residential.pdf
Message 3 of 3
Thank you!
