Message 1 of 5
Can I stay on BT mobile if I switch broadband/phone line?
Hi, my dad is looking to switch to EE and the BT package is quite a bit better. The only problem is that they’re currently paying around £60 per month for 8mb down and 1mb up which is frankly obscene, and full fibre has just been installed in their village so they’re likely going to switch
Is It possible to get BT mobile now, and keep it even if they switch in the future? Thank you
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Can I stay on BT mobile if I switch broadband/phone line?
BT Mobile is no longer accepting new business.
Message 3 of 5
Oh, thanks! All of the packages are listed but it just takes you to the EE website 🙂
Anonymous
Not applicable
Message 4 of 5
If he has  a decent handset there are any number of cheap SIM only deals around. Just be sure to check the Ofom Web site for expected coverage & then test before committing.
Message 5 of 5
Thank you 🙂
