Message 1 of 3
Can't get PAC code as message won't send
2 REPLIES 2
Message 2 of 3
Re: Can't get PAC code as message won't send
then try CS 03301234150
Message 3 of 3
Hi there @olever
Thanks for coming here 🙂
Could you try sending the text when WiFi is turned off, does this send?
For ways to get the PAC please see the How do I get a PAC? page.
Thanks.
Leanne.
