Message 1 of 3
Can't get a 5G signal
Hi
I have a Samsung S23 Ultra (5g is enabled), on a 5G BT mobile plan and in the summer I had the sim card replaced - but still cannot get a 5G signal where ever I travel in the UK.
What do I need to do to get a 5G signal?
Almost seems to me that somewhere within BT's prehistoric systems there's a setting on my account that's preventing 5g - but maybe that's me being cynical after years of having support problems with BT...
2 REPLIES 2
Message 2 of 3
Re: Can't get a 5G signal
Have you tried phoning CS 03301234150 and they should be able to help
Message 3 of 3
Thanks for the response
I'd tried calling BT Support back in the summer - and it was on the back of that they they sent out a new sim - they did no investigative work just took a guess (erroneously) that it was a an issue with the sim.
Therefore before I ring again and spend hours on the phone getting pushed from one department to another which is my normal experience with BT Support - I thought I might try the community to see if anyone else had experienced a similar issue and what steps they'd taken to resolve.
