Message 1 of 20
Cancel mobile
How do you cancel mobile , don’t want number or move it just need to cancel it , says manage your service but doesn’t tell you how to stop it or cancel it , just goes around in circles .
Tags (1)
19 REPLIES 19
Message 2 of 20
Re: Cancel mobile
You will need to call BT 0330.1234.150
Message 3 of 20
Re: Cancel mobile
Thanks , not sure why you’d have to call someone it is 2026 🤷‍♂️
Message 4 of 20
Re: Cancel mobile
@Arryz
It’s about making your life as difficult as possible. They don’t want you to be able to cancel all by yourself, they want you to call them so they can attempt to convince you to stay. That’s the whole reason retention departments exist.
Anonymous
Not applicable
Message 5 of 20
Re: Cancel mobile
You're right it is 2026 and you don't need to phone anyone.
Text PAC to 65075
Or alternatively if you don't want to retain thr number
Text INFO to 85075 from your current number.
Message 6 of 20
Re: Cancel mobile
@Anonymous
Read what the OP has said. He does not want to keep the mobile number or move to a new provider so how will getting a PAC cancel the account as he will not be using it?
Texting the Info number only tells them if they are in contract and how much the fee would be if they cancel while in contract. It does not cancel the account.
Message 7 of 20
Re: Cancel mobile
Message 8 of 20
Re: Cancel mobile
That tells you nothing ! Still doesn’t tell you how ?
Message 9 of 20
Re: Cancel mobile
But pointless if your not keeping number or mobile just want to stop it , not replacing it with anything.
Message 10 of 20
Re: Cancel mobile
Again why would I need a PAC , just want to stop it altogether, not replacing or getting anything new ,, so to try and convince me to have something I no longer need .
