Message 1 of 4
Charges in Singapore
Hello,
I apologise if this is a stupid question. I am travelling to Singapore next month and was wondering what charges (if any) I would incur for texting another UK mobile whilst they are also in Singapore, or calling them. I gather data roaming is very expensive so will use Wi-Fi but when I’m out and about I will want to text when I’m exploring the city.
TIA
3 REPLIES 3
Message 2 of 4
Re: Charges in Singapore
Hi, @EmR welcome to the community and thanks for posting, that's not a stupid question. To text when in Singapore it will cost 44p and calls will cost £1.59/min
For more info on BT Mobile roaming charges check out this link.
Neil
Message 3 of 4
Amazing thank you so much
Message 4 of 4
If your phone can take an eSIM you can get a data only eSIM that will work out a lot cheaper than roaming from your mobile provider.
Google eSIM for Roaming.
