Message 1 of 6
Contacting BT from abroad with no mobile service
Does anyone know how I can contact BT from France to find out why I’m not connected to any mobile network here? I have wifi but can’t call any BT numbers using that. Also can’t login to My BT because  I’m not receiving the passcode even by email. Is there an online chat I can use to contact them? Thanks
5 REPLIES 5
Message 2 of 6
Re: Contacting BT from abroad with no mobile service
Based on: Contacting BT from abroad | BT Help
I believe the number is: +44 150 174 7714
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 6
If you look at the foot of this page there is a "Contact BT" link.
Fix mobile | BT Help
See this link
Using BT Mobile abroad | BT Help
You should also set a spend limit even if it is only £5.
See link
How can I manage my BT Mobile spend? | BT Help
Message 4 of 6
Thanks but the contact is just a phone number which I can’t use as I have no phone connection! It doesn’t work over wifi. I need a way to send a message but there’s no obvious way to do this.
Message 5 of 6
Do you have the "Whats app" app on your phone? If you do you can use its phone function if you are connected to wifi.
Message 6 of 6
Yes I do. Thank you I’ll try that.
