Message 1 of 3
Divert Call from another mobile number
I want to divert another mobile network account number with 250 mins calls to my BT unlimited mobile calls account  will I get charged for any diverted calls and if so what network will show a charge. Thanks George
2 REPLIES 2
Message 2 of 3
Re: Divert Call from another mobile number
You'd be better asking the network who the number you want to divert from is with.
Generally speaking though you'll need to monitor the usage as the 250 mins will then be used for any calls that it diverts to your BT Mobile number.
Message 3 of 3
Thanks I'll do that
