Message 1 of 2
Does BT mobile support wi-fi calling on Motorola G62?
Does BT mobile support wi-fi calling on Motorola G62?  Thinking of buying one from Amazon or wherever then just swapping over the SIM from my current BT mobile handset.
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Does BT mobile support wi-fi calling on Motorola G62?
Because of variations in Android versions it's almost impossible to say. A genuine SIM free UK variant should work but the only way to find out for certain is to try it. You should be covered by the retailer's return policy if not.
