Message 11 of 13
Re: Emergency (death in family) need help calling from USA
Thanks for the response, I got sorted thank. Phoned a family member via WhatsApp, who phoned bt directly on another phone and had on loudspeaker so I could verify id etc. they raised a complaint, they said there is a known issue relating to the exit code 011 which means calls cannot be made, odd that there is no sign posting from BT on this, given the widespread issue.
The issue was resolved the following day, receiving confirmation via text from BT.
Message 12 of 13
Thanks for the response. I'm sorted now but in moments of stress all sensible thoughts don't come easy, you frank advice was very helpful. Was the plan b had I not manged to reach BT (in a very indirect) way.
Message 13 of 13
I'm so glad to hear you were able to get things sorted @Tiredof2026.
Rach
