Message 1 of 4
Gone abroad and forgot to enable the calling
In a word "help". I went abroad and didn't enable the setting to permit usage abroad. I checked everything before I left except making sure the damn SIM is enabled.
I just tried to enable it on the myBt app but it keeps erroring. Every link tells me to call the support on 150 but I can actually do calls at the moment 🤔
I can't find an email for support so I'm hoping someone here has a way to do this...
3 REPLIES 3
Message 2 of 4
Re: Gone abroad and forgot to enable the calling
I think you have to be on the BT network to activate the SIM. Here is the link to the instructions: bt-mobile--what-do-i-need-to-do-before-i-go-abroad-
Message 3 of 4
Thanks for the response. I ended up using my daughter's phone to make the call to BT support. They sorted me within 10 mins after a short security check.
Won't make this mistake again.
Message 4 of 4
Glad you’ve got it sorted.
