Message 1 of 3
Increase Mobile Send Cap to Over £40
Hello, I would like to increase my spend cap on my mobile plan.
When I visit bt.com/mymobile I can see the options to control the spend cap, but the maximum value in the dropdown in £40. Is it possible to increase this over this limit?
2 REPLIES 2
Message 2 of 3
Re: Increase Mobile Send Cap to Over £40
Hello @DrFredEdison.
Thanks for coming here.
The default spend cap is £40 but you can cap what you spend to as low as £0.
I believe £40 is the max on BT mobile.
Katie
Message 3 of 3
@DrFredEdison  As mentioned by @Katie_J who "believes" the cap is £40, here it is confirmed on the BT site!
BT Mobile - Cap Limit
