Message 1 of 5
Mobile add-ons
How much does a data add-on cost. Can I buy it for 1 month only
4 REPLIES 4
Message 2 of 5
Re: Mobile add-ons
If you go to MYBT and login then mobile you should be able to see data plans available to you and. Ost
Message 3 of 5
Re: Mobile add-ons
Hi @georgefox check out this bt.com help page for more info on Mobile add-ons
Neil
Message 4 of 5
Re: Mobile add-ons
Thank you! Most helpful!
Message 5 of 5
Re: Mobile add-ons
Thank you!
