Message 1 of 3
Mobile use abroad (BT Mobile 1GB SIM Only 5G Plan)
Hello,
I have BT "Broadband Package, Fibre 1" with "BT Mobile 1GB SIM Only 5G".
The Mobile part is only for emergencies, I need it from time to time when there is a broadband outage.
Besides from that I use my mobile phone only rarely, but now I need to travel to the EU.
Can I use it there for calls and using the internet?
Are there additional costs (within my 1GB)?
Many thanks!
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: Mobile use abroad (BT Mobile 1GB SIM Only 5G Plan)
Bt mobile still allows roaming in the EU included within your package
https://www.bt.com/help/mobile/going-abroad/using-bt-mobile-abroad/how-do-i-use-bt-mobile-abroad-
you need to make sure roaming is active on phone and turned on in MYBT mobile  you also need to ensure spend limit for foreign is greater than £0 say £5
Message 3 of 3
Thank you, I will do that.
