Message 1 of 3
Network connection issues abroad
Unable to get SMS in my BT mobile whilst abroad in India. I have a dual sim Samsung A50 mobile and it is unable to connect to network in India.
2 REPLIES 2
Message 2 of 3
Re: Network connection issues abroad
do you have international roaming turned on in MYBT?  if so have you set the spend limit to greater than £0 say £5
Message 3 of 3
Thanks for your response. I somehow managed to connect to BT in India via AirTel network this morning.
My dual Sim is AirTel ( India)+ BT UK Sim.
Unfortunately both connect to the same AirTel here.
So I did AirTel connection to 4G and BT to 3G and it worked.
Good of you to respond.
