Message 1 of 3
SIM Activation Issue
I've just put a replacement BT SIM into my phone and activated it via the BT  website.  The phone seems to work ok but I received a  a text from BT (see below).  Any idea what it means please?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: SIM Activation Issue
Google suggests it's an issue sending APN settings to the phone, but as it's just a replacement SIM the settings should already be present. If everything's working & your number is correctly transferred to the new SIM, I'd ignore it.
Message 3 of 3
Thanks, yes the number transferred ok.  I did check the APN settings and I noticed that the MMS settings were incomplete so I guess that could be what the issue was.  Everything seems fine so thanks for putting my mind at rest
