Message 1 of 5
Pixel 8 pro Data Warning
Good afternoon team. Today I got a data warning on my reasonably new Pixel 8pro mobile saying I was over 2GB this monthly period. According to my BT contract I have 38gb of data left until the 18th October.
Is this a phone setting or is it something I should be worried about.
Never seen a warning like this before
Pete
4 REPLIES 4
Message 2 of 5
Re: Pixel 8 pro Data Warning
If it's like my phone, (a Motorola), there is an app to warn you if you go over.  You can set the monthly amount and a warning X GB below it.  It may be you have the same sort of thing and the default warning is set at 2GB.  Have a look at your internet settings.
Message 3 of 5
Thanks Wsh, kinda thought it was a phone issue. I'll change the settings as according to BT I still have 38GB left 🤞👍
Message 4 of 5
It's not a network warning but a software limit set by the phone and has no relevance to your data allowance as per your airtime contract. You can change the limit easily in the phone settings.
Message 5 of 5
Thanks Nigel I've now set the limit to 8GB and no other warnings so far
Pete
