Message 1 of 5
Poor mobile signal at home
I used to have quite good mobile signal around the house but over the last 6 months it has been appalling and I have to call pressed up against the window. I have BT mobile sim in a Motorola phone, I have Halo 3 broadband with complete wifi. Is there anything I can do
4 REPLIES 4
Message 2 of 5
Re: Poor mobile signal at home
Does your mobile not have the ability to do WiFi calling as that would solve your problem
Anonymous
Not applicable
Message 3 of 5
You can find out more here @peterbosher :
https://ee.co.uk/help/help-new/getting-started-and-upgrading/using-your-phone-features/how-do-i-use-...
I have linked to EE because BT Mobile no longer exists, same company though.
Message 4 of 5
Hi thanks you for you prompt reply. I will try that. DOH!
Message 5 of 5
Switch on WIFI Calling.
If you calls cut out whilst on WIFI using WIFI Calling it is because your mobile is sensing an improved 4G signal, so it attempts to reconnect to 4G thereby cutting off your calls.
To fix this and stop your phone trying to connect to 4G, set Network mode to LTE/3G/2G.
