Message 1 of 5
Roaming whilst on dry land in UK !!!
Whilst in Norfolk (Cromer) I got a message that I was using Maritime and would be charged for roaming - why? Am I likely to get a shock on my next bill. If so how can this be legal.
4 REPLIES 4
Message 2 of 5
Re: Roaming whilst on dry land in UK !!!
as Cromer is right on coast is it possible you were on ferry or at the harbour?
Important Information: You're now connected to a Maritime Network, offered on ferries and ships. Making a call costs £2.40 per minute, receiving one costs £1.80 per minute. Texts are 60p to send, but they're free to receive.26 May 2019
as you can see that was 2019 but can't find up to date costs
Message 3 of 5
It's probable that you've connected to a ships maritime system. Turn roaming off in your phone settings while you're at the coast
Message 4 of 5
I was walking along the sea front - but I did discover that I still had roaming enabled following a holiday in Mallorca.
However I do feel that I should have been warned in advance that I was about to use Maritime and would incur charges rather than after I had already done so. You do rather expect to be using UK services whilst here!!
Thanks for the replies
Message 5 of 5
The message will have been sent at the time of connection not after, apart from that I agree with you
