Message 1 of 4
Second sim for galaxy watch6?
Hi
So I'm on a BT Mobile sim only tariff on my Samsung Galaxy S23 Ultra, recently bought the Galaxy Watch6 LTE. Supposed to be able to set up the LTE part but struggling to do so, is it possible with BT Mobile? If yes, what am I doing wrong. If not possible, what are my options?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Second sim for galaxy watch6?
You need an eSIM for the watch, something that BT doesn't support. You'll need to switch to EE.
Message 3 of 4
Had a feeling that would be the case, thank you
Do you have any idea on the costs, is it an extra that can be used on any sim only from ee or is it free on any sim
Message 4 of 4
Hi @DStruct,
I recently set up my Watch 6 on EE. It works out at around £7 extra per month.
Thanks,
Paddy
