Message 1 of 6
Roaming
Does roaming work in France? I can't get EE signal. It is simply not connects
5 REPLIES 5
Message 2 of 6
Re: Roaming
Roaming should be ok in France
Did you set international in MYBT and also set the international spend limit to greater than £0 say £5
Message 3 of 6
Re: Roaming
Sorry what mean international. I was add "roam like home". Is it same?
Message 4 of 6
Re: Roaming
You need to go to MYBT then mobile and activate international roaming and also set international spend cap to £5
You also need roaming activated on your phone
Message 5 of 6
Re: Roaming
Make sure both options for use your phone abroad and international calls are enabled on MyBT.
If it doesn’t connect automatic then do a network search via handset settings. OrangeF or OrangeFrance is usually best network.
Message 6 of 6
Re: Roaming
Hi @GB19260469,
Have you been able to get online ok since your posts last night?
Also, thanks to everyone who posted offering help.
DanielS
