Message 1 of 6
Roaming
We're in Gran Canaria just now and wondering if data roaming can be use on our BT Sim Card phones.
Can't find specific answers on the pages
5 REPLIES 5
Message 2 of 6
Re: Roaming
Data roaming is free with BT MOBILE. Ensure roaming turned on in phone and MYBT and ensure spend limit in mybt set to greater than £0
Message 3 of 6
Re: Roaming
Hi Ian
Thanks for this. My cap in settings is set at £2.50.
If it goes over this amount will I get a warning.
I generally just use hotel WiFi
Pete
Message 4 of 6
Re: Roaming
Hi @petejan1 You'll get a text message when you get close to the spend cap, then another one when you've reached it.
Neil
Message 5 of 6
Re: Roaming
Cheers 👍👍
Message 6 of 6
Re: Roaming
