Message 1 of 4
Upgrade my SIM only plan
I would like to upgrade my SIM plan to increase the data. Previous, I found it could be done by online customer portal but I cannot switch my plan anymore now. When I pressed the change plan button, it will direct you to BT boardband page and ask you if you have BT boardband which is irrelevant .Could anyone help?
3 REPLIES 3
Message 2 of 4
Re: Upgrade my SIM only plan
It's not irrelevant as you get discount on your BT mobile bill for being a BT broadband customer.
If you are a BT customer with a login to MyBT then login before making any changes otherwise just answer 'No'
Message 3 of 4
@Les-Gibson
Sorry that I have not mentioned with more details. After I pressed No, the message below is shown
Sorry…
There aren't any plans that you can move to at this time.
Message 4 of 4
@leunglung
From some other posts it appears BT are suggesting you love to EE and not renewing with BT. That would seem to be the current way forward
