Message 1 of 2
Used duel sim for data abroad but still charged by BT daily rate?
Hi,
I bought a dual e sim when in the US on holiday to save money and I used the data on that for the time there. I switched my BT mobile data off but still charged for 10 days at £6 a day. Anyone know if this is correct and why that is as from what I understood I would only use the data from the Esim. Also on my bill it shows that zero data was used for those 10 days.
thanks
1 REPLY 1
Message 2 of 2
Re: Used duel sim for data abroad but still charged by BT daily rate?
It depends on your phone and the supplier, you may be being charged on a per day basis not for the data but just because the phone is telling the network where you are.
If you want to buy a foreign sim card it is better to buy a physical sim card and change your existing one for that one so there is no confusion.
