Message 1 of 4
Using 4g abroad
I'm currently on holiday in Canary Islands, where I should have 4g, and I cannot send texts or get 4g. I have done what it says online to make sure I can use 4g and it still won't work. Anyone able to help? BT are telling me to call them to solve it but I can't call them because I have no signal.
3 REPLIES 3
Message 2 of 4
Re: Using 4g abroad
presumably you have international calls turned on in MYBT but have you also set international spend limit to greater than £0 say £5?
Message 3 of 4
Re: Using 4g abroad
No as I am in Canary Islands and that is a roam like home destination.
Message 4 of 4
Re: Using 4g abroad
you still need to set a spend limit greater than £0 say £5 even to get roam like at home to work
