Message 1 of 3
Turn off voicemail
I have a Motorola G7 Power mobile phone.It puts all my incoming calls onto voicemail automatically before I can answer.How do I turn off voicemail?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Turn off voicemail
Search the phone setting for "Call Forwarding" & check it isn't set there.
Message 3 of 3
From my G6: Open the Phone app > Settings in the menu (3 dots top right) > Calls > Call forwarding > make sure "Always forward" is off.
