Message 1 of 2
Apple hdr
Ate people getting 4k hdr on bt box pro ?.
I get the atmos but the picture stays in sdr
I've checked all the settings they all seem right and the apple tv settings
On the series it says dolby atmos dolby vision but doesn't activate
I know it don't support dolby vision
So should just activate hdr10 ?
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Apple hdr
This might be down to the AppleTV app detecting that the Pro Box supports Dolby Vision and trying to output that as it's HDR format but if your TV doesn't support Dolby Vision, it will drop back to HD with no HDR. This happened on Sky Stream for a while but was fixed with an update from Apple...
