Message 1 of 4
BT PRO BOX
How many channels can I record on subscription channels IE BT SPORTS is it four or two
Thank you
3 REPLIES 3
Message 2 of 4
Re: BT PRO BOX
Only two IP channels (like BT Sport) at once.
Thank you
Message 3 of 4
Re: BT PRO BOX
If you're running in aerial mode, you can record 2 terrestrial channels and 2 IP channels.
If you're in IP mode, then you can only record 2 at the moment but this could be opened up for more in the future as the IP (streamed) tuners are virtual
Message 4 of 4
Re: BT PRO BOX
Thank you
