Message 11 of 13
Re: BT Pro Box Checking (Unsuccesfully) For Updates
Hi @tweetSP0RT  - there's a new software update (0.8.34) available for your device today. Please can you try the following before midnight tonight:
1) Navigate to software update check and perform a manual software check.
2) If (1) doesn't work, reboot your device and let me know if it performs a software update check at boot and whether this succeeds.
Please let me know how you get on.
Gavin
Message 12 of 13
Thanks @gavinlambourne
The manual update didn't work but a reboot got the software update to work and I'm now on 0.8.34 and that seems to have fixed it! 👍
Message 13 of 13
@gavinlambourne is there any chance of a pinned discussion with change logs and to let people know when updates are available? Thanks
