Message 1 of 2
BT Pro Box
Is there a problem with the Pro Box remote control, batteries only last about 3 to 4 weeks, I've had my TV for 3 years and still using same batteries that came with it.
1 REPLY 1
Message 2 of 2
Re: BT Pro Box
No problem with mine. I've had the box and remote, with the original batteries, for several months and the remote batteries are still working fine. Probably the only bit that is working consistently though. 😣
