Message 1 of 3
BT. Pro Box
Could someone please identify HDMI splitters that work effectively with the BT Pro Box.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT. Pro Box
@saulboatrecommended one a while back. Forum rules prevent direct liks to retailers but search Amazon for B083JVPXDY, as that seems to be the one matching the description.
https://community.bt.com/t5/EE-TV-YouView/Hdmi-output/m-p/2250608#M68199
That's assuming that you want to send the Pro Box to multiple TVs, terminology is sometimes used inaccurately.
Message 3 of 3
Re: BT. Pro Box
Thanks for your rapid response. I’ll follow up on your suggestion.
