Message 11 of 15
Re: BT Pro Remote
That should have been does not work
Message 12 of 15
Re: BT Pro Remote
Well, I thought I'd make my report: on getting home I tried both the IR and Bluetooth methods and neither works. Oh well I'll have to  hang  on to my old one.
Message 13 of 15
Re: BT Pro Remote
I'm well aware that the BT list doesn't cover some of the more obscure makes (and that includes Toshiba who, it seems,  buy in branded TV's from the cheapest vendor) but I would have expected it to work with a major brand like LG.
It might be worth reporting it as faulty and requesting a replacement
Anonymous
Not applicable
Message 14 of 15
Re: BT Pro Remote
@Les-Gibson
I don't think it's an issue with not supporting LG, more that the Pro Box can't see it because there's a Marantz amp in the way. Looks like the box has no support for amps.
Up to the OP whether he wants to connect the box directly to the TV to test.
Message 15 of 15
Re: BT Pro Remote
Thanks. I tried your idea but still no luck. I get the "currently in surround sound" message but the remote does operate the sound on the TV.
The old remote works perfectly.
