Anonymous
Not applicable
Message 11 of 16
Re: BT Set top box control for elderly
This seems to be the latest UK code list for the Flipper & seems to have several codes for both BT & Humax.
https://flipper.zendesk.com/hc/en-us/article_attachments/202365626/Code_List_UK_V4_2015.pdf
Message 12 of 16
Hi
thanks for all the input and ideas.
You can see this is a Dolby box. This is proving to not be an option for non technical elderly people. Just  Too complicated. Control no use for people with arthritis.  If we could get a simple control to work with this box, would be great.
thanks
Anonymous
Not applicable
Message 13 of 16
That's simply a logo. It's no more a Dolby box than it is an HDMI, SCART or Ethernet box.
It looks to be a DTR-T2100 made for BT by Humax. The model number should be on a label on the bottom of the box.
Try the Argos one I suggested. Even if you get the Flipper working I'd say it's going to be impractical with only channel up/down.
Message 14 of 16
That is indeed a Humax manufactured box and has no Bluetooth capability, it is purely Infra-Red which should make your choice of remote easier.
Message 15 of 16
Thanks. None of those codes worked with the Flipper.  Guess will need to try another option.
Anonymous
Not applicable
Message 16 of 16
Just a thought but what is the box actually used for? Is there an active BT TV subscription & if so, for which channels?
Is it still used to record?
Given that most BT content is delivered by third parties now, maybe something app based would be a suitable alternative. Either built into the TV or added with a Firestick or similar with voice search.
