Message 1 of 5
BT T V recordings
My YouView box has failed and requires replacing, one on the way from bt,
question, is there a way off recovering the recordings I have on it
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: BT T V recordings
I’m afraid not.
If all attempts at resetting/recovery have failed, they can only replace the box and you lose any recordings that are on it.
Message 3 of 5
Hi @MP123 and welcome back.
It's been a long time but great to see you again. Any recordings are stored on the box so I'm sorry but @Anonymous is correct.
Cheers
David
Message 4 of 5
@MP123
SD recordings yes - pull the disc out of the box, put it in a caddy, look at it via a Linux distro.
HD recordings no - they are encrypted in such a way that they are tied to the unique ID of the box. Even if it no longer works 😢
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Anonymous
Not applicable
Message 5 of 5
@Midnight_Voicewrote:
@MP123
Bit niche, but an option! 🤣
