Message 11 of 16
Re: BT TV Box Pro - can't play back recording
@RobbieMac
It has sort of happened again, although slightly different.
It's the same BBC 10pm London news programmed recording from the Schedule.
This time it has recorded 42 seconds and I can play back the 42 seconds. The time on Info is 10:33 pm to 10:34 pm. The play back shows towards the end of the weather forecast and the presenter saying they are now going over to the Local News (ie. end of the main News - which itself recorded and played back correctly).
Message 12 of 16
Hi @pamelap
Thanks for posting back.  I am sorry for the problems you're having
I have sent you a private message with instructions on how you can send us over your details.  If you need help reply with the info I need, and we will take it from there.  See Private messages
Thanks,
Robbie
Message 13 of 16
Thanks for taking my call earlier @pamelap .
As discussed this is more than likely a transmission issue as there are no issues with the ProBox etc and it's isolated to one programme.
Cheers
David
Message 14 of 16
@DavidM @RobbieMac
Thanks for all the help.
Message 15 of 16
I also have the same issu recording soaps .. I've a new post
Message 16 of 16
I have suffered from this issue ever since switching to IP channels, I was on the trial and reported this issue but nothing happened. I have lost recording about 20 times now.
