Message 1 of 3
BT TV Box Pro hard reset ..
Once I'm in the boot-up screen where I have factory reset options on there .. how do I select that option ?
The remote up/down keys don't do anything, nor does pressing the OK button.
The remote seems to works ok, as the volume buttons still control the TV.
Cheers
2 REPLIES 2
Message 2 of 3
Re: BT TV Box Pro hard reset ..
The remote is controlling your TV with IR, which won't have changed after resetting your TV Box.  The Bluetooth pairing with your TV Box will have been lost after the reset, so it needs to pair again - follow these instructions to reset it:
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
Message 3 of 3
Cheers Darren,
I'll try re-pairing it
