Message 1 of 4
BT TV Box Pro set up
I just set up my new BT TV Box Pro after subscribing to Big Sport and need some advice please.
Every time I switch on, the box comes up with 'You are not subscribed to Sky Witness HD - Resolve or Back'
How do I stop this please - can I set a default start up program ?
3 REPLIES 3
Message 2 of 4
Re: BT TV Box Pro set up
Hi @tuanton thanks for posting. The TV box doesn't have a "default" channel per se, and will join the last channel selected. Sky Witness HD (Channel 356) is in a package you haven't got in your Big Sport package.
Can you try this and let us know how you get on:
  1. Press the Guide button and select another channel you have in your active subscription (or a Freeview channels like BBC1)
  2. Put the box to active standby, then wake it up again after about 30s
  3. Check that the previously selected channel is shown.
David
Message 3 of 4
Thank you so much...  I used BBC1 HD, and now it's always coming back to this channel.
Message 4 of 4
Great to hear, and thank you for letting us know.
