Message 1 of 4
Setting up BT Pro to be TV Box with a Sony Bravia
I'm trying to set up my BT Pro Box to be the TV Box on a SONY Bravia KD48A9. The Sagemcomm RTIW387 isn't an option.
When I first did this ages ago I used a different manufacturer/model number. For the life of me I can't remember what that was. Any suggestions please?
3 REPLIES 3
Message 2 of 4
Re: Setting up BT Pro to be TV Box with a Sony Bravia
Hi @BillyM and thanks for posting.
Did you manage to get the code you're looking for? Would you mind sharing with the community?
Cheers
David
Message 3 of 4
@DavidM thanks for checking. Someone on the SONY community helped out. Things have moved on with the Bravia I have so that a Pro model is now listed.
When doing a TV Box setup,  select first few letters BT -> BT TV -> (model search) BT -> BTTVBoxPro.
Message 4 of 4
@BillyM that's great, many thanks for coming back and sharing the solution.
Neil
